[GRASS-dev] Re: Problem when loading GRASS 6 raster with large
integer values into R via r.out.bin
Roger Bivand
Roger.Bivand at nhh.no
Tue Sep 23 07:11:15 EDT 2008
On Tue, 23 Sep 2008, Rainer M Krug wrote:
> OK - I finally got around to testing it.
> I installed spgrass6 as well as rgdal from source, as spgrass6 needed
> a newer version of rgdal then available in CRAN (Error: package
> 'rgdal' 0.5-25 was found, but >= 0.5.26 is required by 'spgrass6').
I had to modify rgdal to get writeRAST6() to use writeGDAL() - there was a
bug in otherwise unused code to setting the NODATA value in rgdal. Could
you try this out too? Should I try to trap the verbose messages?
Best wishes,
Roger
> It is working, when using useGDAL=TRUE. See output below:
> In GRASS:
> GRASS 6.3.0 (grass):~/Documents/Projects/AlienSpread/R > r.info -r
> map=ros_2016.max
> min=0
> max=36852
> [Raster MASK present]
> In R:
>> x <- readRAST6("ros_2016.max",useGDAL=FALSE )
> Creating BIL support files...
> Header File =
> /home/rkrug/Documents/Projects/AlienSpread/R/../grass/simulation/.tmp/ecolmod/ros_2016.max.hdr
> World File =
> /home/rkrug/Documents/Projects/AlienSpread/R/../grass/simulation/.tmp/ecolmod/ros_2016.max.wld
> Exporting raster as integer values (bytes=2)
> Using the current region settings...
> north=6247000.000000
> south=6195000.000000
> east=270200.000000
> west=251000.000000
> r=520
> c=192
> 100%
>> range(x[[1]], na.rm=TRUE)
> [1] -31916 30755
>> x <- readRAST6("ros_2016.max",useGDAL=TRUE )
> ERROR 6: SetColorTable() only supported for Byte or UInt16 bands in TIFF format.
> WARNING: Input raster map constains cells with NULL-value (no-data). The
> value 999 was used to represent no-data values in the input
> map.You can specify nodata value by nodata parameter.
> has GDAL driver GTiff
> and has 520 rows and 192 columns
> [1] 0 36852
> I would suggest that you proceed as suggested below.
> Thanks
> Rainer
> On Thu, Sep 18, 2008 at 11:01 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>> Roger Bivand <Roger.Bivand <at> nhh.no> writes:
>>> Markus Neteler <neteler <at> osgeo.org> writes:
>>>> On Wed, Sep 17, 2008 at 10:49 AM, Roger Bivand <Roger.Bivand <at>
>>>> means:
>>>> - the GDAL plugin is no option here since it does not respect current
>>>> region settings
>>>> - r.out.gdal is good since it does the job (AFAIK). Written in C
>>> I can revisit this in relation to using r.out.gdal for GRASS >= 6.3
>>> instead of r.out.bin - in which case I can make r.out.gdal use 32
>>> bits for integers and 64 bits for float/doubles.
>> Committed on R-spatial sourceforge CVS, new flag useGDAL=FALSE for now
>> default, uses Int32 for CELL, so maybe could be tried to see if it works
>> better than r.out.bin.
>> If it does, I'll change writeRAST6() too, change the default to TRUE, and
>> release.
>> Roger
>>> Roger
>>>> Perhaps you mean r.out.gdal.sh?
>>>> Best
>>>> Markus
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
