[GRASS-dev] Addons: r.horizon single point mode segfault
Markus Neteler
neteler at osgeo.org
Thu Sep 25 16:50:52 EDT 2008
I tried to use r.horizon in single point mode but it segfaults:
GRASS 6.4.svn (spearfish60):~/grass64 > gdb r.horizon
GNU gdb 6.6-3mdv2008.0 (Mandriva Linux release 2008.0)
This GDB was configured as "x86_64-mandriva-linux-gnu"...
Using host libthread_db library "/lib64/libthread_db.so.1".
(gdb) r elevation.dem step=30 direction=15 bufferzone=200
coord=-103.75026822,44.43602767
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 47370162098592 (LWP 6037)]
0x0000000000404e1f in calculate (xcoord=-103.75026822,
ycoord=44.436027670000001, buffer_e=6, buffer_w=6, buffer_s=6,
buffer_n=6)
at main.c:1101
1101 z_orig = zp = z[yindex][xindex];
(gdb) bt
#0 0x0000000000404e1f in calculate (xcoord=-103.75026822,
buffer_n=6)
at main.c:1101
#1 0x00000000004036fa in main (argc=6, argv=0x7fff78d62728) at main.c:510
(gdb) bt full
#0 0x0000000000404e8f in calculate (xcoord=-103.75026822,
buffer_n=6)
at main.c:1102
i = 11098
j = -1268384144
l = 32767
k = 0
numDigits = 6
xindex = -19662
yindex = -163781
shadow_angle = 1.6975966453708918e-313
coslat = 6.9532931413279238e-310
latitude = 6.9532931413255523e-310
longitude = 3.1434037398486797e-317
xp = 1840
yp = -9999
inputAngle = 1840
delt_lat = 4.9406564584124654e-324
delt_lon = 1840
delt_east = 6.9532931413318763e-310
delt_nor = 2.0797925572540819e-317
delt_dist = 3.1234217488682763e-317
formatString = "��e��\177\000\000\233�"
hor_row_start = 6
hor_row_end = 484
hor_col_start = 6
hor_col_end = 641
hor_numrows = 478
hor_numcols = 635
arrayNumInt = 490
dfr_rad = 1.3729312770741917e-311
#1 0x000000000040374a in main (argc=6, argv=0x7fffb4660028) at main.c:510
xcoord = -103.75026822
ycoord = 44.436027670000001
module = (struct GModule *) 0x2b5af6ad2660
parm = {elevin = 0x2b5af6ad25c0, dist = 0x60db40, coord =
0x60da80, direction = 0x60d400, horizon = 0x60d9c0,
step = 0x60d4a0, bufferzone = 0x60d540, e_buff = 0x60d5e0, w_buff =
0x60d680, n_buff = 0x60d720, s_buff = 0x60d7e0,
maxdistance = 0x60d900}
flag = {degreeOutput = 0x2b5af6ad2580}
in_proj_info = (struct Key_Value *) 0x60b400
in_unit_info = (struct Key_Value *) 0x611470
What could be the problem here?
thanks
Markus
