[GRASS-dev] starting GIPE modules insertion in main svn
Yann Chemin yann.chemin at gmail.com
Tue Sep 30 13:11:47 EDT 2008
2008/9/30 Glynn Clements <glynn at gclements.plus.com>:
> Martin Landa wrote:
>> > i.qc.modis: classifies binary Quality flags from MODIS reflectance
>> > products (250 & 500m) into values.
>> compilation still fails:
>> CKAGE=\""grassmods"\"
>> -I/home/martin/src/grass_trunk/dist.i686-pc-linux-gnu/include -o
>> OBJ.i686-pc-linux-gnu/qc250a.o -c qc250a.c
>> qc250a.c: In function 'qc250a':
>> qc250a.c:14: error: implicit declaration of function 'swab'
>> make: *** [OBJ.i686-pc-linux-gnu/qc250a.o] Error 1
> Right; you need <unistd.h> for swab().
are there forgiving compilers around, so that this was not required explicitely?
This is on my laptop:
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian
4.3.2-1' --with-bugurl=file:///usr/share/doc/gcc-4.3/README.Bugs
--enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr
--enable-shared --with-system-zlib --libexecdir=/usr/lib
--without-included-gettext --enable-threads=posix --enable-nls
--with-gxx-include-dir=/usr/include/c++/4.3 --program-suffix=-4.3
--enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc
--enable-mpfr --enable-cld --enable-checking=release
--build=x86_64-linux-gnu --host=x86_64-linux-gnu
--target=x86_64-linux-gnu
Thread model: posix
gcc version 4.3.2 (Debian 4.3.2-1)
> BTW, what purpose does making qc250chan an "unsigned int" serve? CELL
> is an "int" and the "unsigned" qualifier doesn't make any difference
> to the operations which are actually being performed upon the values.
The functions were designed out of GRASS, with stronger restrictions
on reading in data.
This should be obsolete in GRASS now indeed.
> Also, the fact that the swab() calls are there seems to imply that the
> data was imported incorrectly in the first place. If any byte swapping
> needs to be done, it should normally be done when the data is
> imported.
My mastering of binary reading is weak, so I guess you make sense,
but technically I would feel weak to modify it. For what I undestand
it was initially meant
(outside of GRASS) to isolate a small number of bits for & comparison.
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
YiKingDo: http://yikingdo.unblog.fr/
