[GRASS-dev] Re: [GRASS GIS] #315: v.db.join fails in winNative Grass 6.3 for sqlite driver
GRASS GIS trac at osgeo.org
Tue Sep 30 15:20:15 EDT 2008
  Reporter:  aprasad       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  Database      |     Version:  6.3.0
Resolution:                |    Keywords:  v.db.join
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by aprasad):
 I found out the reason - the v.db.join script in winNative does not parse
 the input arguments with the correct case ...for example $GIS_OPT_column
 is not recognized in the script - when I changed it to $GIS_OPT_COLUMN it
 worked....this is true for other parsed input arguments....hopefully this
 will help correct the bug.
Ticket URL: <http://trac.osgeo.org/grass/ticket/315#comment:1>
