[GRASS-dev] Re: grass-dev Digest, Vol 36, Issue 4
Paolo Cavallini
cavallini at faunalia.it
Thu Apr 2 16:18:16 EDT 2009
Laura Toma ha scritto:
> If you're looking for a fast version of r.cost, try r.terracost. I
> think I put it at some point in the add-ons repository. Otherwise it's
> available from my website. Depending on the amount of memory you
> specify on the command line, it runs in memory (an optimized CPU
> algorithm) or an I/O algorithm.
I keep on believing that useful additional plugins will always receive
so little attention and testing that it will be always be difficult to
be sure they are good enough to be included in src. Unless an easy
install like the R one will be devised.
All the best.
Paolo Cavallini: http://faunalia.it/pc
