[GRASS-dev] [GRASS GIS] #545: r.cost warning on negative values
GRASS GIS trac at osgeo.org
Fri Apr 3 02:53:11 EDT 2009
 Reporter:  pcav         |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.4.0
Component:  default      |     Version:  6.3.0
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 In case ov even a few negative values, r.cost fails badly (running
 forever).
 If the cost map contains any negative values, it should either
 generate a fatal error, or treat such cells as nulls (exclude them or
 use the null_cost= value) and generate a warning.
 Thanks Glynn for the hint.
Ticket URL: <https://trac.osgeo.org/grass/ticket/545>
