[GRASS-dev] problem with a description html file
Yann Chemin yann.chemin at gmail.com
Sun Apr 5 11:54:27 EDT 2009
Hello Martin,
yes, since I just copied a valid GRASS description html into this one,
I believe it is a different problem.
here is the error on the command line.
root at siduxbox:/home/yann/tmp/grass_yann/imagery/i.modis.qc# make
gcc -I/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/include  -g -O2
  -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
-I/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/main.o -c main.c
gcc -L/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/lib
-Wl,--export-dynamic
-Wl,-rpath-link,/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/lib
-L/usr/lib/  -o
/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/bin/i.modis.qc
OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/mod09A1a.o
OBJ.i686-pc-linux-gnu/mod09A1c.o OBJ.i686-pc-linux-gnu/mod09A1d.o
OBJ.i686-pc-linux-gnu/mod09A1e.o OBJ.i686-pc-linux-gnu/mod09A1sa.o
OBJ.i686-pc-linux-gnu/mod09A1sb.o OBJ.i686-pc-linux-gnu/mod09A1sc.o
OBJ.i686-pc-linux-gnu/mod09A1sd.o OBJ.i686-pc-linux-gnu/mod09A1se.o
OBJ.i686-pc-linux-gnu/mod09A1sf.o OBJ.i686-pc-linux-gnu/mod09A1sg.o
OBJ.i686-pc-linux-gnu/mod09A1sh.o OBJ.i686-pc-linux-gnu/mod09A1si.o
OBJ.i686-pc-linux-gnu/mod09A1sj.o OBJ.i686-pc-linux-gnu/mod09A1sk.o
OBJ.i686-pc-linux-gnu/mod09Q1a.o OBJ.i686-pc-linux-gnu/mod09Q1b.o
OBJ.i686-pc-linux-gnu/mod09Q1c.o OBJ.i686-pc-linux-gnu/mod09Q1d.o
OBJ.i686-pc-linux-gnu/mod09Q1e.o OBJ.i686-pc-linux-gnu/mod09Q1f.o
OBJ.i686-pc-linux-gnu/mod11A2a.o OBJ.i686-pc-linux-gnu/mod11A2b.o
OBJ.i686-pc-linux-gnu/mod11A2c.o OBJ.i686-pc-linux-gnu/mod11A2d.o
-lgrass_gis -lgrass_datetime -lz      -lm  -lz
if [ "/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/bin/i.modis.qc"
!= "" ] ; then GISRC=/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/demolocation/.grassrc70
GISBASE=/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu
PATH="/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/bin:$PATH"
PYTHONPATH="/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/etc/python:$PYTHONPATH"
LD_LIBRARY_PATH="/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/bin:/home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/lib:"
LC_ALL=C /home/yann/tmp/grass_yann/dist.i686-pc-linux-gnu/bin/i.modis.qc
--html-description < /dev/null | grep -v '</body>\|</html>' >
i.modis.qc.tmp.html ; fi
Segmentation fault
make: *** [i.modis.qc.tmp.html] Error 1
rm i.modis.qc.tmp.html
Thanks a lot,
Yann
2009/4/5 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2009/4/5 Yann Chemin <yann.chemin at gmail.com>:
>> Could you please help,
>> I have updated i.modis.qc, and it compiles well.
>> However, the html file somehow makes an error on compilation of the module.
>> The compilation fails because of that one.
> I guess your are referring to trunk. See SUBMITTING_DOCS for supported
> tags. Can you send error log?
> M.
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Yann Chemin
Mobile: +33 (06) 10 11 39 26
Home: +33 (02) 35 27 08 20,
Address: Gite de Mortagne,
16 rue de la chenaie,
76110 Bec de Mortagne,
France
Perso: http://www.freewebs.com/ychemin
YiKingDo: http://yikingdo.unblog.fr/
