[GRASS-dev] [GRASS GIS] #548: grass7: v.reclass segfaults on string
	column
    trac at osgeo.org
    Tue Apr  7 09:05:02 EDT 2009
#548: grass7: v.reclass segfaults on string column
 Reporter:  mlennert     |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-trunk
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 With today's devel7 trunk, v.reclass segfaults when trying to use a string
 column as reclass criterium. Using nc_spm_06 demo data:
 v.reclass in=boundary_county out=test_recl column=DOT_GROUP_
 segfaults, whereas
 v.reclass in=boundary_county out=test_recl2 column=DOT_COUNTY
 works as expected (DOT_COUNTY is integer).
 In grass65svn, both commands work as expected.
 This also obviously makes v.dissolve fail on such columns.
 Backtrace attached.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/548>
