[GRASS-dev] Re: [GRASS GIS] #520: r.terraflow/iostream does not
respect STREAM_DIR option
trac at osgeo.org
Wed Apr 8 05:56:13 EDT 2009
#520: r.terraflow/iostream does not respect STREAM_DIR option
Reporter: mmetz | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by neteler):
New patch uploaded with bugfix only (so back to /var/tmp/ default). The
bug is AFAIK here:
[source:grass/branches/develbranch_6/raster/r.terraflow/main.cc#L179]
The assignment to opt seems to fail:
opt->mem = atoi(mem->answer);
opt->streamdir = streamdir->answer;
G_debug(0,"DEBUG streamdir %s",streamdir->answer);
G_debug(0,"DEBUG opt %s",opt->streamdir);
leads to
GRASS 6.5.svn (spearfish60):> r.terraflow elev=elevation.10m \
filled=elevation10m.filled dir=elevation10m.mfdir \
swatershed=elevation10m.watershed accumulation=elevation10m.accu \
tci=elevation10m.tci d8cut=500 memory=800
stats=elevation10mstats.txt\
STREAM_DIR=/tmp --o
D0/0: DEBUG streamdir /var/tmp/
D0/0: DEBUG opt /var/tmp/
Confusing... Interestingly, if I use (note the d typo):
r.terraflow elev= ... STREAM_dDIR=/tmp
the module does not fail. Apparently parse_args() fails?
Ticket URL: <https://trac.osgeo.org/grass/ticket/520#comment:7>
