[GRASS-dev] error in v.in.dxf compilation
Vincent Bain
bain at toraval.fr
Wed Apr 8 11:57:15 EDT 2009
Compiling grass65 (revision 36627) I got an error in v.in.dxf
compilation :
gcc
-I/home/vincent/grass65_devel/dist.x86_64-unknown-linux-gnu/include -I/usr/include/ -g -O2 -I/usr/local/include -DPACKAGE=\""grassmods"\" -I/home/vincent/grass65_devel/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/write_vect.o -c write_vect.c
write_vect.c: Dans la fonction «get_field_cat» :
write_vect.c:125: erreur: «DXf_BUF_SIZE» undeclared (first use
in this function)
write_vect.c:125: erreur: (Each undeclared identifier is
reported only once
write_vect.c:125: erreur: for each function it appears in.)
make: *** [OBJ.x86_64-unknown-linux-gnu/write_vect.o] Erreur 1
May it be due to recent changes to write_vect.c ?
Yours,
Vincent
