[GRASS-dev] uploaded r.terracost to GRASS Addons
Andrew Danner
adanner at cs.swarthmore.edu
Wed Apr 8 14:16:14 EDT 2009
Markus Neteler wrote:
> On Thu, Apr 2, 2009 at 7:08 PM, Laura Toma <ltoma at bowdoin.edu> wrote:
>> If you're looking for a fast version of r.cost, try r.terracost. I think
>> I put it at some point in the add-ons repository. Otherwise it's available
>> from my website. Depending on the amount of memory you specify on the
>> command line, it runs in memory (an optimized CPU algorithm) or an I/O
>> algorithm.
> I have (upon request from Laura) now uploaded r.terracost to Addons:
> svn checkout https://svn.osgeo.org/grass/grass-addons/raster/r.terracost
> r.terracost
> It is r.terracost-1.1 but with various include file fixes, a new
> description.html,
> a new Makefile. Also I didn't not include the IOSTREAM lib as it is already
> present in GRASS 6 in the lib/ directory.
> Compilation:
> make MODULE_TOPDIR=/path/to/grass6svn/
> Currently, I get these two errors:
> iterator.cc: In member function ‘int Iterator::getNext(ijCostSource*)’:
> iterator.cc:42: error: no match for ‘operator=’ in ‘* out =
> ((Iterator*)this)->Iterator::tile->Tile::<anonymous>.mappedTile<costSourceType>::<anonymous>.genericTile<T>::get
> [with T = costSourceType](((int)((short
> int)((Iterator*)this)->Iterator::iMarker)), ((int)((short
> int)((Iterator*)this)->Iterator::jMarker)))’
> input.h:160: note: candidates are: ijCostType<costSourceType>&
> ijCostType<costSourceType>::operator=(const
> ijCostType<costSourceType>&)
> make: *** [OBJ.x86_64-unknown-linux-gnu/iterator.o] Error 1
get() returns a costSourceType. You want an
typedef ijCostType<costSourceType> ijCostSource returned by getComplex
(I think)
Index: iterator.cc
--- iterator.cc (revision 36633)
+++ iterator.cc (working copy)
@@ -39,7 +39,7 @@
if (iMarker > tileSizeRows - 1)
return 0;
- *out = tile->get(iMarker, jMarker);
+ *out = tile->getComplex(iMarker, jMarker);
> Makefile:15: warning: overriding commands for target
> `/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/bin/r.terracost'
> /home/neteler/grass64//include/Make/Module.make:14: warning: ignoring
> old commands for target
> c++ -I/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/include -g
> -O2 -DPACKAGE=\""grassmods"\"
> -I/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/include -o
> OBJ.x86_64-unknown-linux-gnu/main.o -c main.cc
> main.cc: In function ‘void printGrid(AMI_STREAM<ijCostType<float>
> main.cc:432: warning: deprecated conversion from string constant to
> ‘char*’
> main.cc: In function ‘int main(int, char**)’:
> main.cc:976: error: no matching function for call to
> ‘AMI_sort(AMI_STREAM<distanceType>*&, AMI_STREAM<distanceType>**,
> distanceIJCompareType*, int&, char*&)’
> make: *** [OBJ.x86_64-unknown-linux-gnu/main.o] Error 1
> Fixes appreciated.
There is no matching signature for that kind of AMI_sort. The last two
parameters are new and missing in the iostream library. Laura, do you
know what these parameters are for and is there an iostream update?
For the const warnings
Index: stats.h
--- stats.h (revision 36633)
+++ stats.h (working copy)
@@ -28,14 +28,14 @@
#define HAVE_STATS
-int noclobberFile(char *);
+int noclobberFile(const char *);
class statsRecorder : public ofstream {
private:
Rtimer tm;
void *bss;
public:
- statsRecorder(char *fname);
+ statsRecorder(const char* fname);
Index: stats.cc
--- stats.cc (revision 36633)
+++ stats.cc (working copy)
@@ -113,7 +113,7 @@
int
-noclobberFile(char *fname) {
+noclobberFile(char * const fname) {
int fd=-1;
while(fd<0) {
@@ -162,7 +162,7 @@
-statsRecorder::statsRecorder(char *fname) {
+statsRecorder::statsRecorder(char * const fname) {
for suspiciousness (missing template arguments):
Index: input.h
--- input.h (revision 36633)
+++ input.h (working copy)
@@ -194,15 +194,14 @@
cout << *this;
- friend ostream& operator << (ostream& s, const ijCostType &ct) {
+ friend ostream& operator << (ostream& s, const ijCostType<T> &ct) {
s << "(" << ct.getI() << "," << ct.getJ() << ": " << ct.cs << ")";
return s;
- friend int operator == (const ijCostType &a, const ijCostType &b) {
+ friend int operator == (const ijCostType<T> &a, const ijCostType<T> &b) {
return (basicIJType(a) == basicIJType(b) && a.cs == b.cs);
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
