[GRASS-dev] error in v.in.dxf compilation
    massimo di stefano
    massimodisasha at yahoo.it
    Wed Apr  8 18:09:41 EDT 2009
Seems the error persists :
sasha a sasha:~/gis/grass6_devel$ svn info
Path: .
URL: https://svn.osgeo.org/grass/grass/branches/develbranch_6
Repository Root: https://svn.osgeo.org/grass
Repository UUID: 15284696-431f-4ddb-bdfa-cd5b030d7da7
Revision: 36640
Node Kind: directory
Schedule: normal
Last Changed Author: neteler
Last Changed Rev: 36638
Last Changed Date: 2009-04-08 17:54:16 +0200 (mer, 08 apr 2009)
sasha a sasha:~/gis/grass6_devel$ cd /home/sasha/gis/grass6_devel/vector/
v.in.dxf
sasha a sasha:~/gis/grass6_devel/vector/v.in.dxf$ make
gcc -I/home/sasha/gis/grass6_devel/dist.i686-pc-linux-gnu/include  -g -
O2    -I/usr/local/include    -DPACKAGE=\""grassmods"\"  -I/home/sasha/
gis/grass6_devel/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-
gnu/write_vect.o -c write_vect.c
write_vect.c: In function ‘get_field_cat’:
write_vect.c:125: error: ‘DXf_BUF_SIZE’ undeclared (first use in this
function)
write_vect.c:125: error: (Each undeclared identifier is reported only
once
write_vect.c:125: error: for each function it appears in.)
make: *** [OBJ.i686-pc-linux-gnu/write_vect.o] Error 1
Massimo Di Stefano
massimodisasha a yahoo.it
epifanio on   irc.freenode.net  /join gfoss
Il giorno 08/apr/09, alle ore 18:00, grass-dev-request a lists.osgeo.org
ha scritto:
> Da: Vincent Bain <bain a toraval.fr>
> Data: 08 aprile 2009 17:57:15 GMT+02:00
> A: grass-dev <grass-dev a lists.osgeo.org>
> Oggetto: [GRASS-dev] error in v.in.dxf compilation
> Hi,
> Compiling grass65 (revision 36627) I got an error in v.in.dxf
> compilation :
>        gcc
>        -I/home/vincent/grass65_devel/dist.x86_64-unknown-linux-gnu/
> include -I/usr/include/  -g -O2    -I/usr/local/include    -DPACKAGE=
> \""grassmods"\"  -I/home/vincent/grass65_devel/dist.x86_64-unknown-
> linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/write_vect.o -c
> write_vect.c
>        write_vect.c: Dans la fonction «get_field_cat» :
>        write_vect.c:125: erreur: «DXf_BUF_SIZE» undeclared (first use
>        in this function)
>        write_vect.c:125: erreur: (Each undeclared identifier is
>        reported only once
>        write_vect.c:125: erreur: for each function it appears in.)
>        make: *** [OBJ.x86_64-unknown-linux-gnu/write_vect.o] Erreur 1
> May it be due to recent changes to write_vect.c ?
> Yours,
> Vincent
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Un allegato HTML ? stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090409/f341674e/attachment.html
