[GRASS-dev] Re: [GRASS GIS] #539: Error on "Display Map" in wxpython
trac at osgeo.org
Wed Apr 8 20:32:58 EDT 2009
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: MSWindows Vista | Cpu: Unspecified
Comment (by cnielsen):
Still no resolution to this bug, perhaps it relates to the change from
mapdisp.py
pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite
map
To mapdisp_window.py:
pdc.DrawBitmap(bitmap, wx.Point(coords[0], coords[1]), True) # draw the
composite map
The error says "expected argument 3 of type 'int'" and it seems that it is
still looking for "coords[1]" when in the latter case it is instead
getting "true" since "coords[1]" has been put within wx.Point as part of
arg 2.
Trying to trace this back I noticed that the
grass-6.5.svn/etc/wxpython/vdigit folder is empty. Apparently vdigit isn't
compiling at all. Ideas?
Ticket URL: <http://trac.osgeo.org/grass/ticket/539#comment:4>
