[GRASS-dev] Programming in GRASS
Markus Neteler neteler at osgeo.org
Fri Apr 10 03:35:09 EDT 2009
don't worry too much about ximgview/main.c. It is perhaps unlikely that you
ever use it... And GRASS is modular, so the rest isn't affected.
Markus
On Fri, Apr 10, 2009 at 7:52 AM, dasuni kannangara <dasuni7 at gmail.com> wrote:
> Thanks, I am using Eclipse now and i opened the grass codes (grass-6.4.0RC3)
> using eclipse. I could successfully compile it using console (make command).
> but when i try to build it using eclipse , it gives 21 errors from
> grass-6.4.0RC3/visualization/ximgview/main.c file. I cannot figure out how
> to solve these errors. i have attached a screenshot. please tell me how to
> solve these errors.
> ________________________________
> View this message in context: Re: Programming in GRASS
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
