[GRASS-dev] Programming in GRASS
dasuni kannangara dasuni7 at gmail.com
Fri Apr 10 10:21:52 EDT 2009
thanx. but grass/gis.h is already there. i just added another grass folder to ximgview to check whether it solves.what is the location which i should search for grass/gis.h??
dasuni kannangara wrote:
> I am using Eclipse now and i opened the grass codes (grass-6.4.0RC3)
> using eclipse. I could successfully compile it using console (make
> command). but when i try to build it using eclipse , it gives 21
> errors from grass-6.4.0RC3/visualization/ximgview/main.c file. I
> cannot figure out how to solve these errors. i have attached a
> screenshot. please tell me how to solve these errors.
The errors all indicate that  wasn't included, or is
empty.
Why does the "ximgview" directory have a "grass" subdirectory? That
isn't present in the SVN repository.
Glynn Clements
grass-dev mailing list
grass-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-dev
View this message in context: http://n2.nabble.com/Programming-in-GRASS-tp2588377p2616419.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090410/8616c7fd/attachment.html
