[GRASS-dev] Re: [GRASS GIS] #539: Error on "Display Map" in wxpython
GRASS GIS trac at osgeo.org
Sat Apr 11 18:57:43 EDT 2009
  Reporter:  cnielsen         |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  major            |   Milestone:  6.5.0
 Component:  wxGUI            |     Version:  svn-develbranch6
Resolution:                   |    Keywords:
  Platform:  MSWindows Vista  |         Cpu:  Unspecified
Comment (by jef):
 Replying to [comment:8 cnielsen]:
 > Replying to [comment:7 jef]:
 > > see also http://trac.osgeo.org/osgeo4w/ticket/37#comment:13 ff
 > That ticket includes information about vdigit and nviz but they're still
 not functioning in the osgeo4w builds right?
 Yes.
 > Do I need to run {{{package.cmd}}} to make a functioning GUI? If so I'm
 missing {{{h:\windows\wxPython-src-2.8.9.1}}} and my attempts to get it
 from the wxpython/wxwidgets svn were unsuccessful...
 That's the wxPython build.   I started off with
 http://www.wxpython.org/download.php#binaries there (including the devel
 packages), but IIRC I couldn't get the libraries to work.
 So I resorted to building wxPython with VC++ 2008 Express Edition -
 leading to the described problems.  Later I tried with VS2003, which
 didn't significantly changed anything.
 > I'm still missing something, but I see that you didn't need --python or
 --wxwidgets in your osgeo4w builds.
 Exactly.  GRASS is not aware of distutils, which AFAIK should be used to
 build python extensions.
Ticket URL: <http://trac.osgeo.org/grass/ticket/539#comment:9>
