[GRASS-dev] [GRASS GIS] #551: WinGRASS-6.4_RC3 error creating
location with EPSG codes.
trac at osgeo.org
Sun Apr 12 19:40:31 EDT 2009
#551: WinGRASS-6.4_RC3 error creating location with EPSG codes.
Reporter: isaacullah | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Python | Version: 6.4.0 RCs
Keywords: create location epsg | Platform: MSWindows XP
Cpu: Unspecified |
Trying to create a location with EPSG codes in WinGRAS-6.4_RC3 using the
WX-GUI gives following error: "Unable to read EPSG codes: string index out
of range"
The path to epsg file is correct, and the file is normal. It seems
wingrass cannot parse the epsg file.
Work around: Change directory symbol in path to epsg file from "\" to "/".
Enter a known epsg code (eg. search spatialrefernce.org for the correct
code) in the EPSG box, and press "next". Grass creates new location.
This work around does not let one "Browse EPSG codes", however. If one
trys to do so, the same error "Unable to read EPSG codes: string index out
of range" pops up.
This bug occurs in both osgeo4W version and the native installer version
of WinGRASS-6.4_RC3
Ticket URL: <http://trac.osgeo.org/grass/ticket/551>
