[GRASS-dev] resize raster
Vincent Bain bain at toraval.fr
Tue Apr 14 13:05:51 EDT 2009
Hi Quentin,
If your vector contains a single polygon, I would do it this way :
* v.to.rast (with the option type=area)
* then assign the result to a mask with r.mask
* finally run r.mapcalc on your raster with a simple identity
(outrast=inrast)
Le mardi 14 avril 2009 à 17:43 +0200, Quentin Page a écrit :
> hello,
> I search the function which cut a raster part according  to limits given
> by a vector (polygon). These two features are within the same projection.
> thanks a lot
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
