[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not
work
trac at osgeo.org
Wed Apr 15 06:11:52 EDT 2009
#73: r.out.gdal tiff output does not work
Reporter: helena | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.out.gdal, tiff
Platform: Unspecified | Cpu: Unspecified
Comment (by mmetz):
Replying to [comment:31 mlennert]:
> Is this still an issue, or have Markus' patches solved the problem ?
My patch only adds safety checks to make sure that the selected GDAL data
type covers the range of the raster band to be exported and that the given
null value is within the range of the selected GDAL data type. That would
be an enhancement, not a bugfix.
AFAICT, r.out.gdal as it is now (without the patch) can produce perfectly
readable output, but it is possible to produce bogus output without these
two safety checks. This is now a trade-off between code complexity and
additional checks of user-specified options. I would opt to keep the code
simple, also because the manual has been updated.
In any case, it would be great if this ticket could be solved before the
final release of 6.4.
Ticket URL: <http://trac.osgeo.org/grass/ticket/73#comment:32>
