[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not work
GRASS GIS trac at osgeo.org
Wed Apr 15 07:58:31 EDT 2009
  Reporter:  helena       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  critical     |   Milestone:  6.4.0
 Component:  Raster       |     Version:  svn-trunk
Resolution:               |    Keywords:  r.out.gdal, tiff
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by hamish):
 Replying to [comment:32 mmetz]:
 > My patch only adds safety checks to make sure that the selected
 > GDAL data type covers the range of the raster band to be exported
 > and that the given null value is within the range of the selected
 > GDAL data type. That would be an enhancement, not a bugfix.
 Pretend you are r.out.gdal iterating through the raster cells to output.
 You come across a NULL cell. You have to write down some value, and are
 completely constrained to options available in the output type. What do
 you write out? Overflow/wrap the type? type min? type max? well (as things
 were) whatever you do is going to be arbirtary, and thus could lead to
 data loss, which is grounds for a most serious blocker bug.
 > also, because the manual has been updated.
 that is easily modified, so shouldn't stop us.
 > In any case, it would be great if this ticket could be solved
 > before the final release of 6.4.
 yup
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/73#comment:38>
