[GRASS-dev] [GRASS GIS] #554: wxGUI location wizard: Search in description with 0 hits
GRASS GIS trac at osgeo.org
Thu Apr 16 01:15:51 EDT 2009
 Reporter:  hamish           |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect           |      Status:  new
 Priority:  major            |   Milestone:  6.4.0
Component:  wxGUI            |     Version:  6.4.0 RCs
 Keywords:  location wizard  |    Platform:  MSWindows XP
      Cpu:  x86-32           |
 in the latest 6.4.0svn wingrass build from osgeo4w--
 - startup with wxgui.
 - Define new location via location wizard.
 - by epsg code (list comes up now, great to see that fixed!)
 - Search in description: ___ something with no hits, eg 4326 or typo
 At this point the list of codes is empty and the following error message
 appears on the DOS console window:
  File
 "C:\OSGeo4W\apps\grass\grass-6.4.0svn\etc\wxpython\gui_modules\location_wizard.py",
 line 1365, in OnSearch
     self.epsgcode = self.epsglist.Search(index=1, str=value)[0]
 TypeError: 'NoneType' object is unsubscriptable
 so I guess two things are needed:
 - only try to grab epsg code to fill in "EPSG code: ____" box if >=1
 result was found, and
 - automatically reload EPSG codes before each new search (if 0 hits then
 the 'search in desc' box is unusable until you press the Reload EPSG Codes
 button.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/554>
