[GRASS-dev] [GRASS GIS] #556: ftbfs: g.cairocomp
GRASS GIS trac at osgeo.org
Thu Apr 16 06:06:57 EDT 2009
 Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  7.0.0
Component:  default      |     Version:  svn-trunk
 Keywords:  g.cairocomp  |    Platform:  Linux
      Cpu:  x86-32       |
 when building grass 7 I get the following error in g.cairocomp:
 main.c: In function 'init_xlib':
 main.c:118: error: implicit declaration of function
 'cairo_xlib_surface_get_xrender_format'
 main.c:118: warning: assignment makes pointer from integer without a cast
 make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
 I have libcairo2-dev version 1.2.4, the fn is not found in
 /usr/include/cairo/*.h
 This change says that >=1.5.8 is now needed:
 http://trac.osgeo.org/grass/changeset/36349
 Could a check be added to ./configure to test for
 cairo_xlib_surface_get_xrender_format()?
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/556>
