[GRASS-dev] Re: [GRASS GIS] #553: wx and tcltk GUI: changing default GUI returns error
GRASS GIS trac at osgeo.org
Thu Apr 16 06:58:11 EDT 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  Python        |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  wxgui gis.m
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 same thing happens with 6.4.0rc4 native wingrass install.
 the release notes say that the tcltk gui is unavailable, but I *can* start
 it if I start in the msys mode, close the wxGUI and type "gis.m" on the
 command line. weirdly to access maps in spearfish PERMANENT from user1 I
 have to type in the map name manually with @PERMANENT, in the avail map
 listing the PERMANENT mapset is closed.
 some space could be saved by not shipping d.m with native wingrass (it
 also starts, but without xmons it is useless)
 strangely "g.gui tcltk" from the msys command line does not work.
 (and the GRASS> prompt is still ridiculously long for an 80 col terminal)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/553#comment:3>
