[GRASS-dev] v.net.visibility memory leak? - was Re: [GRASS-user]
traveling salesman problem in air
Markus Neteler
neteler at osgeo.org
Thu Apr 16 07:42:54 EDT 2009
On Thu, Apr 16, 2009 at 11:02 AM, Markus Metz
<markus.metz.giswork at googlemail.com> wrote:
> Markus Neteler wrote:
>> On Thu, Apr 16, 2009 at 8:28 AM, Markus Metz
>>>> I have run valgrind to check for a memory leak (Linux 64 bit box):
>>>> Some funky "uninitialised byte(s)" problem appears... (inline also a
>>>> debug msg?):
>>> Some leaks in the vector libs could disappear if
>>> Vect_set_release_support()
>>> is called just before closing vectors in v.net.visibility. Maybe the
>>> output
>>> of valgrind becomes a bit shorter and more readable.
>> I have added for input and output Vect_set_release_support().
> I'm missing Vect_destroy_line_struct(sites) and
> Vect_destroy_cats_struct(cats) in visibility.c, report() and main.c,
> count(). Maybe that helps.
added...
> Further on, it seems that...
> - Something's wrong with the RTree, I guess with re-inserting nodes.
> Debugging the RTree is a major nightmare...
I can imagine :(
> - Memory allocated by buf_alloc() in diglib is never free-d, must be fixed
> in diglib, in theory easy.
ok...
[btw:
Attaching centroids...
100%
centroids: 1.000000
areas to cidx: 0.000000 <<--- should this be G_debug()?
Number of nodes: 4491
Number of primitives: 330643
That's in lib/vector/Vlib/build_nat.c
Here the new valgrind output:
==16713==
WARNING: Vector map <graph> already exists and will be overwritten
==16713== Syscall param write(buf) points to uninitialised byte(s)
==16713== at 0x7035D70: write (in /lib64/libc-2.8.so)
==16713== by 0x6FD6EE9: _IO_file_write (in /lib64/libc-2.8.so)
==16713== by 0x6FD7DF8: _IO_do_write (in /lib64/libc-2.8.so)
==16713== by 0x6FD89F6: _IO_switch_to_get_mode (in
/lib64/libc-2.8.so)
==16713== by 0x6FD736F: _IO_file_seekoff (in /lib64/libc-2.8.so)
==16713== by 0x6FCCDA9: ftell (in /lib64/libc-2.8.so)
==16713== by 0x5D41F4D: dig_ftell (file.c:40)
==16713== by 0x5D42963: dig__write_head (head.c:56)
==16713== by 0x4E57FE4: V1_open_new_nat (open_nat.c:127)
==16713== by 0x4E57434: Vect_open_new (open.c:565)
==16713== by 0x402FCF: main (main.c:85)
==16713== Address 0x4028009 is not stack'd, malloc'd or (recently)
free'd
Building topology for vector map <graph>...
Registering primitives...
330643 primitives registered
661286 vertices registered
primitives: 422.000000
Building areas...
100%
0 areas built
0 isles built
areas: 1.000000
Attaching islands...
isles: 0.000000
100%
centroids: 1.000000
Number of points: 0
Number of lines: 330643
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
==16713==
==16713== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 2 from
1)
==16713== malloc/free: in use at exit: 455,310 bytes in 119 blocks.
==16713== malloc/free: 4,047,822 allocs, 4,047,703 frees,
1,604,431,177 bytes allocated.
==16713== For counts of detected errors, rerun with: -v
==16713== searching for pointers to 119 not-freed blocks.
==16713== checked 2,415,312 bytes.
==16713==
==16713==
==16713== 100 bytes in 1 blocks are still reachable in loss record 1
of 10
==16713== at 0x4C1F144: calloc (vg_replace_malloc.c:397)
==16713== by 0x5D3F976: dig__alloc_space (allocation.c:81)
==16713== by 0x5D4983D: buf_alloc (portable.c:55)
==16713== by 0x5D49B0E: dig__fread_port_L (portable.c:150)
==16713== by 0x5D4872D: dig_Rd_Plus_head (plus_struct.c:614)
==16713== by 0x4E579D6: Vect_open_topo (open.c:722)
==16713== by 0x4E5693A: Vect__open_old (open.c:229)
==16713== by 0x4E57029: Vect_open_old (open.c:415)
==16713== by 0x402F7F: main (main.c:81)
==16713==
==16713==
==16713== 144 bytes in 2 blocks are still reachable in loss record 2
of 10
==16713== at 0x4C214A1: realloc (vg_replace_malloc.c:429)
==16713== by 0x5296148: G__realloc (alloc.c:111)
==16713== by 0x52A4EB2: set_env (env.c:156)
==16713== by 0x52A4C44: read_env (env.c:104)
==16713== by 0x52A54CE: G__getenv (env.c:317)
==16713== by 0x52A5410: G_getenv (env.c:271)
==16713== by 0x52B36A0: G_location (location.c:63)
==16713== by 0x52B36B8: G__location_path (location.c:78)
==16713== by 0x52B3644: G_location_path (location.c:41)
==16713== by 0x52AEB0B: G__gisinit (gisinit.c:57)
==16713== by 0x402DF7: main (main.c:42)
==16713==
==16713==
==16713== 480 bytes in 1 blocks are still reachable in loss record 3
of 10
==16713== at 0x4C2136E: malloc (vg_replace_malloc.c:207)
==16713== by 0x5296135: G__realloc (alloc.c:109)
==16713== by 0x4E46602: Vect_add_dblink (field.c:226)
==16713== by 0x4E47333: Vect_read_dblinks (field.c:645)
==16713== by 0x4E56D61: Vect__open_old (open.c:344)
==16713==
==16713==
==16713== 3,492 (3,468 direct, 24 indirect) bytes in 33 blocks are
definitely lost in loss record 4 of 10
==16713== by 0x529603E: G__malloc (alloc.c:41)
==16713== by 0x52B36F3: G__location_path (location.c:80)
==16713==
==16713==
==16713== 3,696 (96 direct, 3,600 indirect) bytes in 3 blocks are
definitely lost in loss record 5 of 10
==16713== by 0x4E4F2F2: Vect__new_line_struct (line.c:69)
==16713== by 0x4E4F2A8: Vect_new_line_struct (line.c:59)
==16713== by 0x40360E: load_lines (main.c:242)
==16713== by 0x4031B1: main (main.c:119)
==16713==
==16713==
==16713== 1,224 bytes in 5 blocks are indirectly lost in loss record 6
of 10
==16713== by 0x5D4D4CD: dig_alloc_cats (struct_alloc.c:279)
==16713== by 0x4E5B07E: Vect__Read_line_nat (read_nat.c:266)
==16713== by 0x4E5AD24: V2_read_line_nat (read_nat.c:138)
==16713== by 0x4E5AE99: V2_read_next_line_nat (read_nat.c:192)
==16713== by 0x4E5A8EE: Vect_read_next_line (read.c:76)
==16713== by 0x4036C0: load_lines (main.c:245)
==16713==
==16713==
==16713== 2,400 bytes in 3 blocks are indirectly lost in loss record 7
of 10
==16713== by 0x5D3FAF5: dig__frealloc (allocation.c:144)
==16713== by 0x5D3F991: dig__alloc_space (allocation.c:83)
==16713== by 0x5D4D3C9: dig_alloc_points (struct_alloc.c:239)
==16713== by 0x4E5B200: Vect__Read_line_nat (read_nat.c:309)
==16713==
==16713==
==16713== 4,096 bytes in 8 blocks are still reachable in loss record 8
of 10
==16713== by 0x5F545D6: RTreeNewNode (node.c:49)
==16713== by 0x5F5364C: RTreeNewIndex (index.c:29)
==16713== by 0x5D4B68D: dig_spidx_free_isles (spindex.c:93)
==16713== by 0x5D4B6CD: dig_spidx_free (spindex.c:106)
==16713== by 0x4E40BA8: Vect_close (close.c:117)
==16713== by 0x403290: main (main.c:135)
==16713==
==16713==
==16713== 4,096 bytes in 8 blocks are definitely lost in loss record 9 of 10
==16713== by 0x5D4B522: dig_spidx_init (spindex.c:36)
==16713== by 0x5D43C94: dig_init_plus (plus.c:94)
==16713== by 0x4E564B2: Vect__open_old (open.c:146)
==16713==
==16713==
==16713== 439,206 bytes in 55 blocks are still reachable in loss record 10 of 10
==16713== by 0x52CE929: G_store (store.c:36)
==16713== by 0x52C29D9: G_set_program_name (progrm_nme.c:52)
==16713== by 0x52AEAD2: G__gisinit (gisinit.c:51)
==16713==
==16713== LEAK SUMMARY:
==16713== definitely lost: 7,660 bytes in 44 blocks.
==16713== indirectly lost: 3,624 bytes in 8 blocks.
==16713== possibly lost: 0 bytes in 0 blocks.
==16713== still reachable: 444,026 bytes in 67 blocks.
==16713== suppressed: 0 bytes in 0 blocks.
This looks definitely better!
I assume that the Vect_set_release_support() was suggested only for debugging.
Fixed in 6.4.0svn, 6.5.svn and 7 as r36752, r36753, r36754.
Thanks, MarkusM for spotting the problem.
Markus
