[GRASS-dev] Re: [GRASS GIS] #551: WinGRASS-6.4_RC3 error creating
location with EPSG codes.
trac at osgeo.org
Sat Apr 18 08:45:05 EDT 2009
#551: WinGRASS-6.4_RC3 error creating location with EPSG codes.
Reporter: isaacullah | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.4.0
Component: Python | Version: 6.4.0 RCs
Resolution: fixed | Keywords: create location epsg
Platform: MSWindows XP | Cpu: Unspecified
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [ticket:551 isaacullah]:
> Trying to create a location with EPSG codes in WinGRAS-6.4_RC3 using the
WX-GUI gives following error: "Unable to read EPSG codes: string index out
of range"
> The path to epsg file is correct, and the file is normal. It seems
wingrass cannot parse the epsg file.
> Work around: Change directory symbol in path to epsg file from "\" to
"/". Enter a known epsg code (eg. search spatialrefernce.org for the
correct code) in the EPSG box, and press "next". Grass creates new
location.
> This work around does not let one "Browse EPSG codes", however. If one
trys to do so, the same error "Unable to read EPSG codes: string index out
of range" pops up.
> This bug occurs in both osgeo4W version and the native installer version
of WinGRASS-6.4_RC3
Fixed in RC4, see also #554 for additional fixes.
M.
Ticket URL: <http://trac.osgeo.org/grass/ticket/551#comment:2>
