[GRASS-dev] Re: [GRASS GIS] #554: wxGUI location wizard: Search in
description with 0 hits
trac at osgeo.org
Sun Apr 19 04:23:03 EDT 2009
#554: wxGUI location wizard: Search in description with 0 hits
Reporter: hamish | Owner: martinl
Type: defect | Status: assigned
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: location wizard
Platform: MSWindows XP | Cpu: x86-32
Comment (by neteler):
Replying to [comment:4 martinl]:
> Replying to [ticket:554 hamish]:
> > - Search in description: ___ something with no hits, eg 4326 or typo
> you search in the description, not in the codes - so you get empty list.
Use "Reload EPGS codes" to reload the list.
Could the search code be changed to also search in the EPSG codes? I get
regularly trapped that it isn't possible (often I want to search for a
code to see if I recalled the number correctly)
Markus
Ticket URL: <https://trac.osgeo.org/grass/ticket/554#comment:6>
