[GRASS-dev] [GRASS GIS] #563: problem with v.in.dxf 3d polyline import
GRASS GIS trac at osgeo.org
Sun Apr 19 05:05:22 EDT 2009
 Reporter:  vincent      |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.5.0
Component:  Vector       |     Version:  unspecified
 Keywords:  dxf 3d       |    Platform:  Unspecified
      Cpu:  Unspecified  |
 With v.in.dxf, importing a dxf layer which contains 3d polylines (e.g.
 contourlines) results in a "flat" vector map; lines are properly imported
 but all line heights are set to 0.
 Attached is a test.dxf file (contour lines are stored in layers named cl_m
 and cl_s).
Ticket URL: <http://trac.osgeo.org/grass/ticket/563>
