[GRASS-dev] Re: [GRASS GIS] #562: patch proposal: do not show
delimiters for empty labels in case of multiple cats per feature
trac at osgeo.org
Mon Apr 20 01:23:00 EDT 2009
#562: patch proposal: do not show delimiters for empty labels in case of multiple
cats per feature
Reporter: mlennert | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: default | Version: svn-trunk
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by dersh):
I think that it really depends on the data.
For example, if you were doing samples at several locations once a month,
but a few of the actual samples got lost in processing, then I would say
that you are correct that missing data should be shown.
On the other hand if the data is "missing" because it is the result of a
query, ("select where value > 10" or "select where date < 2007-01-01")
then you intentionally don't want to show some data, and having those
slashes doesn't show any useful information.
I would argue that if you actually are missing data, then it should be
entered into the database as missing (-999, "M" whatever is appropriate
for the type of data), rather then just leaving it blank.
Perhaps the best answer would be to a flag for which behavior is desired.
I would also propose that the user should be able to select what delimiter
is used. "/" is not a bad choice for the default, but perhaps the user
wants "\n" instead? That way the labels are not a cluttered in some cases.
Another flag for d.vect?
Ticket URL: <https://trac.osgeo.org/grass/ticket/562#comment:2>
