[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does
not work
Markus Metz
markus.metz.giswork at googlemail.com
Mon Apr 20 05:17:23 EDT 2009
Glynn Clements wrote:
> Markus Metz wrote:
>> OK, but I have tested r.out.gdal with type = GDT_Int32 and nodata =
>> 0x80000000. Same result: NULL cells become -2147483648 but the nodata
>> value in the metadata says 2147483648 (gdalinfo on the export output),
> Yes. I know. Running "r.out.gdal ... nodata=0x80000000" is
> misinterpreting what I was saying, as r.out.gdal parses nodata= as a
> floating-point value.
> I'm talking about using (GDT_Int32)0x80000000 (i.e. -2^31)
I think I slowly begin to understand. You suggest to use
(GDT_Int32)0x80000000 for both the GDAL metadata info and the GDAL
raster data although GDAL metadata nodata is double?
When using a default nodata value, what I want to get in the exported
map is identical values for the metadata nodata value and the value
assigned to NULL cells. GDAL metadata nodata value is always double
(GDALSetRasterNoDataValue()), the value assigned to NULL cells is of the
selected GDAL datatype. So 0x80000000 for GDT_Int32 will be 2^31 in
metadata and -2^31 in the data if passed as such to the corresponding
GDAL functions, (double ) 0x80000000 for metadata info and (GDT_Int32)
0x80000000 for raster data.
> or
> (GDT_UInt32)0x80000000 (i.e. +2^31) as appropriate for the destination
> type.
I was assuming that not only CELL, but also FCELL and DCELL maps may be
exported as GDT_UInt32. Then 2^31 can occur in the raster to be
exported. Actually, I was assuming that any GRASS raster type may be
exported as any GDAL data type.
>>>> For r.out.gdal, there was discussion about not to override user options
>>>> and instead issue an error or a warning (going for error now) that the
>>>> nodata value is out of range.
>>> This isn't about overriding user options, but interpreting them
>>> correctly.
>> Close to "the module knows better" which is not desirable according to
>> Dylan and Moritz.
> No, the opposite. Writing code which does what the user asks for
> rather than doing something else which is easier to code.
What if the user asks for a nodata value to be out of range, i.e. really
wants it to be out of range, leading to a mismatch between the nodata
value in the metadata and the value assigned to NULL cells in the GDAL
export? I understood that this was requested to be possible.
>> If r.out.gdal should support out of range nodata values, and the nodata
>> value is read with atof(), 2^31 should stay 2^31and not be cast to
>> -2^31. The GUI description of the nodata option says that it is of type
>> float (actually it's a double), i.e. suggesting that any value that is
>> representable as floating point is ok.
> That's a limitation of the parser. If the input is CELL, then the
> nodata value which the input data uses isn't any kind of float. It
> might be more correct to have separate int/float nodata options.
> OTOH, GDAL's no-data value is always a double, even for integer data.
I would rather stick to GDAL's method of handling nodata options and try
to mimic that in r.out.gdal.
>>> OTOH, reading as FP allows you to specify +2^31 as the nodata value
>>> when exporting CELL as UInt32. Maybe it would be better to read as
>>> double then cast to the destination type.
>> Hmm, then it would be no longer possible to have an out-of-range nodata
>> value in the metadata. I would support that solution, but it was
>> explicitly requested to obey all user options when the -f flag is used,
>> also writing the nodata value as it is to the metadata. It is then up to
>> the user to figure out what happened to the NULL cells, assuming that
>> the user knows what happens when using the -f flag.
> I can see some point to that, but may be confusing for the user, who
> may assume that they're talking about the data's no-data value when
> they're actually specifying GDAL's no-data value.
That's why there are warnings if there will be a mismatch between the
GDAL metadata nodata value and the GDAL raster nodata value (out of
range test). And having this mismatch is only possible with the -f flag,
when forcing r.out.gdal to use exactly the given parameters and options.
The GDAL API documentation says "To clear the nodata value, just set it
with an "out of range" value." This is currently possible with the -f
flag, but r.out.gdal then does not give any information on what value is
assigned to NULL cells, only what nodata value is written to the metadata.
>>> Even so, 0x80000000 is still the ideal value for exporting CELL data
>>> to either UInt32 or Int32. You just have to pick the correct
>>> interpretation of it (unsigned int or signed int respectively).
>> The current as well as previous policy of r.out.gdal is to not to
>> interpret the nodata value. It is written as is (currently double) to
>> metadata, same like e.g. gdal_translate -a_nodata behaves.
> It doesn't have any choice about interpreting it. nodataopt->answer is
> a char*, while GDALSetRasterNoDataValue() expects a double. There are
> several ways to convert a char* to a double; atof() may be the
> simplest to implement, but is it the most correct?
No idea. If you can't think if a more correct way, that is it I'm
afraid. You're definitively more of an expert on that than I am.
>> and 0 as default nodata value for UInt32?
> No; 0 is a valid data value. Use +2147483648, as that will never occur
> in the input data. Or even any value >= 2147483648.
Values >= 2147483648 may well occur in the input data if they are FCELL
or DCELL.
>> Getting tired of this UInt32 example, but again:
>> (unsigned int) 0x80000000 is 2^31, yes?
> Yes.
>> Then this value would be right
>> in the middle of the range of UInt32, and can cause data loss when
>> exporting a FCELL raster as UInt32 .
> In that case, use (double) 0xFFFFFFFFU, which will never exist in CELL
> or FCELL data.
(double) 0xFFFFFFFFU = 4294967295 = 2^32 - 1 can not exist in FCELL or
DCELL data?
> Maybe the default should depend upon the input type?
IMHO, the output type should be considered as well when selecting a
default nodata value. As above, what I want to get is a GDAL metadata
nodata value that is identical to the value assigned to NULL cells for
the given GDAL datatype.
I suggest to
ignore the GRASS raster type, use the actual GRASS raster data range. If
the selected GDAL datatype can not hold the range present in the GRASS
raster (raster_min < type_min || raster_max > type_max), print helpful
information and abort export, force proceed with -f flag. (Already
implemented)
Exporting FCELL or DCELL as some integer type is up to the user, only
range is checked, no precision warning. (Status quo)
custom nodata value:
make sure the GDAL metadata nodata value is identical to the value
assigned to NULL cells. Abort export on mismatch, force proceed with -f
flag. (Already implemented)
use the actual GRASS raster data range to determine a default nodata
value for the given GDAL datatype:
if (type_min < raster_min)
nodata = type_min;
else if (type_max > raster_max)
nodata = type_max;
else {
/* presence of NULL cells yet unknown, just warn */
G_warning(_("Could not determine a safe default nodata value, using
type_min"));
nodata = type_min;
For GDT_Int32, type_min would be -2147483648 = (GDT_Int32) 0x80000000
Not implemented, currently using type_min for integer types and NaN for
floating point types. For floating point types (GDT_Float32 and
GDT_Float64), maybe stick to NaN or use nodata = raster_min - 1 ?
NULL cells were exported and selected nodata value was present -> data loss:
Abort export, force proceed with -f flag in case of custom nodata value.
Abort export in case of default nodata value. (Not implemented,
currently -f flag overrides)
Sounds OK?
