[GRASS-dev] Re: [GRASS GIS] #565: r.colors: glibc double free or
corruption with -ae
trac at osgeo.org
Wed Apr 22 00:36:12 EDT 2009
#565: r.colors: glibc double free or corruption with -ae
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.5.0
Component: Raster | Version: svn-develbranch6
Resolution: | Keywords: r.colors
Platform: Linux | Cpu: x86-32
Comment (by glynn):
Replying to [comment:1 hamish]:
> here we go, happened again..
G> r.univar -g map1
min=-23.8941449919674
max=1999.8932486971
#7 0x0804b386 in get_fp_stats (name=0x9b72640 "map1", mapset=0x9b72030
"user7",
statf=0xbfd05f94, min=3.2146326349358647, max=7.601348984183665,
geometric=0,
geom_abs=1) at stats.c:136
If any of the raster values lie outside of the range specified by the
min/max parameters, memory corruption will occur due to modifying an out-
of-range array element.
FWIW, I have noticed a bug in get_fp_stats(...,geom_abs=1): if the range
is signed, values which are closer to zero than both min and max will also
modify an out-of-range array element.
I'll fix that one shortly, but it won't help if the min/max parameters are
bogus.
Ticket URL: <https://trac.osgeo.org/grass/ticket/565#comment:4>
