[GRASS-dev] Re: [GRASS GIS] #456: Undefined references when
building grass 6.4 rc4
trac at osgeo.org
Wed Apr 22 18:08:02 EDT 2009
#456: Undefined references when building grass 6.4 rc4
Reporter: fundawang | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Comment (by glynn):
Replying to [comment:22 fundawang]:
> If configure.in is to be modified, you should detect cairo-xlib rather
than cairo. It provides extra linking libs:
$ pkg-config --libs cairo-xlib
-lcairo -lX11
But the cairo driver doesn't use the Xlib backend. It can optionally use
the Xrender backend; currently, we do:
cairo="cairo cairo-ft"
if test -n "$USE_X11"; then
cairo="$cairo cairo-xlib-xrender"
fi
CAIROINC=`pkg-config --cflags $cairo`
If you build --without-x11, the cairo driver should still be built,
supporting all of the file-based backends (PNM, PNG, BMP, PDF, PS, SVG).
This should require X libraries.
If you build --with-x11, {{{pkg-config ... cairo-xlib-xrender}}} should
provide all of the necessary switches.
Ah, I see; 6.4 has the Xrender code in the cairo driver but doesn't have
the corresponding tests in configure.in. Someone who cares about 6.4 needs
to back-port them from 7.0.
Ticket URL: <https://trac.osgeo.org/grass/ticket/456#comment:23>
