[GRASS-dev] PostGreSQL functionality in GRASS.
kavitesh.singh at wipro.com
Thu Apr 23 00:19:48 EDT 2009
Hi All,
It is a novice question, I want to know how is the PostGreSQL used in
GRASS. My initial thought was that it stores the map attributes and
spatial information in PostGreSQL or similar databases. On the other
hand I also feel the dataset which GRASS uses to store map information
(raster/vector) has all the spatial information. I can use a dataset and
use in on any other system installation without copying anything from
database.
Can someone please elaborate on this.
Regards,
Kavitesh Singh
Please do not print this email unless it is absolutely necessary.
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments.
WARNING: Computer viruses can be transmitted via email. The recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email.
www.wipro.com
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090423/b300968e/attachment.html
