[GRASS-dev] v.buffer
Paolo Cavallini
cavallini at faunalia.it
Thu Apr 23 02:50:11 EDT 2009
Hi all.
AFAIK, v.buffer has been deprecated, and replaced by v.buffer2. As a
result, the qgis-plugin-grass cannot use the command anymore. Of course
it is possible and esy to replace the command, but care should be taken
when linking to different grass versions. Wouldnì't it be easier/more
robust to either change the name of the new module back to v.buffer, or
to ln?
See: https://trac.osgeo.org/qgis/ticket/1629
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
