[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does
not work
Markus Metz
markus.metz.giswork at googlemail.com
Thu Apr 23 07:34:20 EDT 2009
Glynn Clements wrote:
> Markus Metz wrote:
>>> - all floating point: IEEE's NaN
>> Problem with NaN? According to IEEE 754, x == y is always FALSE if
>> either x or y or both are NaN. Assuming (nodata =
>> GDALGetRasterNoDataValue()) == NaN,
Sorry, should have been nodata = GDALGetRasterNoDataValue() and
isnan(nodata)
>> then going through all cells if
>> (cell == nodata) will always be FALSE, nodata cells may not be detected?
>> Depends on each implementation of nodata detection? Can be solved for
>> GRASS, but how is this done in all other GIS applications?
> if (x == nodata || isnan(nodata) && isnan(x))
> isnan() is C99 and POSIX, or it can be defined as e.g.:
> #define ISNAN(x) ((x) != (x))
As previously in ticket #73, I created a MASK and then exported
elevation from nc_spm_08 as FLOAT32, once with nodata=0 and once with
default nodata value NaN for GDT_Float32.
GRASS 7 r.in.gdal: all ok
GRASS 7 r.external: all ok
Other GIS applications:
QGIS 1.0.0: all ok
gvSIG 1.1.2: doesn't support the nodata concept, and NaN is displayed
like 0.0
SAGA 2.0.3: display ok for NaN, but cell query gives 0.0 instead of NaN
or nodata, and NoData info says 0
ESRI ArcMap 9.2: display ok for nodata=0, not ok when using NaN, NaN
displayed like value 0.0, and cell query gives NaN instead of nodata
Considering this, rather use e.g. raster_min - 1 as default nodata value
for GDAL floating point datatypes?
