[GRASS-dev] r.surf.fractal [was: v.buffer]
Hamish
hamish_b at yahoo.com
Thu Apr 23 09:06:49 EDT 2009
Hamish ha scritto:
> > in devbr6 and relbr6_4 I have added backwards compatibility aliases
> > for the removed options. so all should be ok again.
Paolo wrote:
> Thanks for this.
> Same thing happens for r.surf.fractal (option d=float has been changed
> in option dimension=float). Could this also be fixed?
it shouldn't need to be. the parser will accept shortened names as long
as they do not conflict. Therefore a call to 'r.surf.fractal d=' will
work the same in grass 6.3 as it will in 6.4.
So names can be lengthened without worry.
Does it not work??
> More generally: is there a list of changed options, so we
> can try and fix them all?
I don't know of an automatic way of testing for that, but there should
not be any.
maybe r.terraflow's STREAM_DIR option?, but we should fix whatever the
new caps option bug is in the parser and leave that in caps for 6.x.
Hamish
