[GRASS-dev] r.surf.fractal [was: v.buffer]
Hamish hamish_b at yahoo.com
Thu Apr 23 09:08:36 EDT 2009
> Paolo wrote:
> > Same thing happens for r.surf.fractal (option d=float has been changed
> > in option dimension=float). Could this also be fixed?
> it shouldn't need to be. the parser will accept shortened names as long
> as they do not conflict. Therefore a call to 'r.surf.fractal d=' will
> work the same in grass 6.3 as it will in 6.4.
> So names can be lengthened without worry.
see  http://grass.osgeo.org/wiki/Module_command_line_parser
H
