[GRASS-dev] Re: [GRASS GIS] #569: grass compilation error due to freetype
GRASS GIS trac at osgeo.org
Thu Apr 23 18:12:35 EDT 2009
  Reporter:  neuba    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  normal   |   Milestone:  6.5.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:
  Platform:  Linux    |         Cpu:  x86-32
Comment (by glynn):
 Replying to [ticket:569 neuba]:
 > I got this error in grass 6.5 svn and their is the following error, in
 the v.label.sa directory:
 A couple of notes about submitting bug reports:
 1. All build output should be in the C locale; use e.g. "LC_ALL=C make
 ..." when compiling. Output from running GRASS programs should be in the C
 locale unless the report specifically relates to a localisation issue, or
 if you need to post the original text because you can't reproduce the
 error.
 2. Any blocks of literal text, e.g. program output, should be enclosed in
 triple braces to preserve formatting; see the WikiFormatting link above
 the comment box for details.
Ticket URL: <http://trac.osgeo.org/grass/ticket/569#comment:1>
