[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does
not work
Markus Metz
markus.metz.giswork at googlemail.com
Fri Apr 24 02:16:09 EDT 2009
Glynn Clements wrote:
> Markus Metz wrote:
>> Considering this, rather use e.g. raster_min - 1 as default nodata value
>> for GDAL floating point datatypes?
> If fabs(raster_min) is large, raster_min - 1 won't be exactly
> representable, and may be rounded to raster_min. You would need to
> subtract a value which depends upon the exponent.
> Also, the input data may contain -DBL_MAX. For FCELL, if the map is
> large enough, it's possible that *all* finite values occur in the
> data.
I was (honestly! I was listening to you:-)) thinking about something like
if (raster_min > type_min) {
unsigned int i = 0;
while ((float)(raster_min - ++i) == raster_min);
nodata = raster_min - i;
else if (raster_max < type_max) {
unsigned int i = 0;
while ((float)(raster_max + ++i) == raster_max);
nodata = raster_max + i;
else
nodata = 0; /* or whatever fallback */
for GDT_Float32 but did not want to go into so much detail.
> The question is: is GDAL's no-data value allowed to be any FP value,
> or must it be finite? I'm guessing that the GDAL documentation doesn't
> say (similarly, I don't think it's documented whether GRASS
> FCELL/DCELL values are allowed to be infinite).
> Actually, this may depend upon the format. If a format supports FP,
> the format's specification may dictate whether or not NaN and/or
> inifinities are considered valid.
Hmm. I thought the point of using GDAL is that r.out.gdal does *not*
have to bother about the format's specifications. IMHO, if there is
reason to assume that NaN and/or infinities are not valid for any of the
formats supporting FP, r.out.gdal should not use NaN and/or infinities.
OTOH, NaN and infinities are described in the IEEE FP standard. I would
avoid format-specific code in r.out.gdal, considering the large number
of supported formats and the number of creation options for each format
(for each format sometimes differing between datatypes, e.g. GeoTIFF).
