[GRASS-dev] i.rectify still chokes on @mapset
Markus Neteler neteler at osgeo.org
Sat Apr 25 03:30:53 EDT 2009
On Wed, Apr 15, 2009 at 7:44 PM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 15/04/09 19:14, Markus Neteler wrote:
>> On Wed, Apr 15, 2009 at 7:12 PM, Isaac Ullah <iullah at asu.edu> wrote:
>>> To clarify,  the error is exactly this:
>>> i.rectify group=central_hasa_square_60_69 at PERMANENT
>>> input=central_hasa_square_60_69.1 at PERMANENT extension=rectify_test
>>> order=1
>>> Input raster map <central_hasa_square_60_69.1 at PERMANENT> does not exist
>>> in
>>> group <central_hasa_square_60_69 at PERMANENT>.
>>>  Try:
>>> central_hasa_square_60_69.alpha
>>> Exit!
>> three questions:
>> - in which mapset are you currently? (g.gisenv)
>> - does the group really exist? (g.list group)
>> - please post the content of the group file
> As the message says, the group file contains central_hasa_square_60_69.1,
> but not central_hasa_square_60_69.1 at PERMANENT. I would guess that the
> problem is  in line 166 of imagery/i.rectify/main.c (ref to trunk) where you
> have
> if (strcmp(ifile->answers[m], ref.file[n].name) == 0) {
> without stripping the @mapset from the file name and so the comparison with
> the files in the group fails.
> Don't know how this is handled elsewhere, but should be fairly trivial to
> correct, I would guess.
Same in v.lidar.growing (maybe others).
Do we need a new function to strip off the @mapset from a file name?
Cannot find it...
Markus
