[GRASS-dev] Re: [GRASS-user] v.lidar.growing dbmi: Protocol error
Markus Neteler
neteler at osgeo.org
Sun Apr 26 04:02:58 EDT 2009
(moved here from grass-user)
On Fri, Apr 24, 2009 at 11:51 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Apr 22, 2009 at 10:58 PM, Jack Lonsdale <lonsdale at unbc.ca> wrote:
>> I am continuing to try and use Grass to process my LiDAR data. However,
>> having completed v.lidar.edgedetect successfully I am unable to complete
>> v.lidar.growing
>> firstly, just to check, the 'first' parameter is the raw dataset? If not
>> how do I create the first return dataset?
>> Secondly, if I run the following:
>> v.lidar.growing input=alrf_subs_edge at lonsdale output=alrf_subs_grow
>> first=alrf_subs_raw tj=0.2 td=0.6
>> All I get is a dbmi:Protocol error, It was impossible to open this
>> table!
> ha! I guess I found the error.
> Please try again *without* specifying the mapset (@lonsdale). If it is
> not in the path, use g.mapsets (-s for GUI) to add it.
> Runs, right?
> The bug is here:
> sprintf(buf, "SELECT Interp,ID FROM %s_edge_Interpolation",
> in_opt->answer);
> db_append_string(&sql, buf);
> in_opt->answer contains (in your case) the @mapset part which causes
> the DBMI engine to crash. So that should be easy to fix in the module.
> @devs: how to strip off the mapset part of a name? Don't remember...
Fix proposal attached, using G__name_is_fully_qualified().
I still don't like to use a G__ function but it seems to work.
Submit?
Markus
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090426/7815fbfd/v.lidar.growing.obj
