[GRASS-dev] [GRASS GIS] #571: v.db.addcol: fails if path contains spaces
GRASS GIS trac at osgeo.org
Tue Apr 28 03:39:10 EDT 2009
 Reporter:  pcav         |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.0
Component:  default      |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 When adding a column, if the path to the dbf (possibly this is true also
 for other DB drivers?) contains spaces), the command fails. First found on
 QGIS https://trac.osgeo.org/qgis/ticket/1632, now submitted to grass upon
 suggestion by rblazek
Ticket URL: <https://trac.osgeo.org/grass/ticket/571>
