[GRASS-dev] Re: [GRASS-user] Grass 6.4 & python.
Colin Nielsen
colin.nielsen at gmail.com
Thu Apr 30 10:31:42 EDT 2009
I've updated the CompileOnWindows page to reflect this improved
PYTHONPATH, and I'll add it to the native installer in the next
version. Thanks.
-Colin
On Thu, Apr 30, 2009 at 12:03 AM, Hamish <hamish_b at yahoo.com> wrote:
>> # Set the PYTHONPATH variable
>> PYTHONPATH="$GISBASE/etc/python:$GISBASE/Python25:$PYTHONPATH"
>> export PYTHONPATH
> I don't know if it matters much for PYTHONPATH, but there is a small
> issue with $PATH if set as above. If $PYTHONPATH is previously empty
> then the search path becomes:
> The final ":" at the end causes the pwd (".") to be added to the path.
> that isn't always a problem but it can lead to unexpected results.
> if the "$EMPTY:" comes first in the $PATH then it is more of a problem
> because the unexpected copy is run not the system copy. e.g. it's a lot
> easier for a nasty person to inject a program called "ls" into your home
> directory and trick you into running it by mistake.
> so longer but better is
> if [ -z "$PYTHONPATH" ] ; then
> PYTHONPATH="$GISBASE/etc/python:$GISBASE/Python25"
> else
> fi
> export PYTHONPATH
> Hamish
