[GRASS-dev] New winGrass release
Moskovitz, Bob
Bob.Moskovitz at conservation.ca.gov
Thu Apr 30 19:02:47 EDT 2009
I am getting a fatal error when open a mapset or create a new mapset. In both cases, g.proj.exe crashes (as you can see by the attached jpg)
Bob Moskovitz
Research Analyst I
Seismic Hazard Evaluation Project
California Geological Survey
http://gmw.consrv.ca.gov/shmp
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
> -----Original Message-----
> From: grass-dev-bounces at lists.osgeo.org
> [mailto:grass-dev-bounces at lists.osgeo.org]On Behalf Of Colin Nielsen
> Sent: Thursday, April 30, 2009 1:37 PM
> To: grass-windows at lists.osgeo.org; grass-dev
> Subject: [GRASS-dev] New winGrass release
> I have posted an updated winGrass based on releasebranch_6_4. Among
> others, updates includes:
> * fixed location wizard
> * bat startup window is minimized (can't hide it sorry)
> * hopefully some of the issues with non-english characters
> (please test)
> Please post any problems.
> Note: I'm going to be unavailable to release updated versions until
> June 1st but the steps required to do so are quite simple if someone
> else wants to take over until then.
> -Colin
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Type: image/jpeg
Desc: error.jpg
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090430/ee1e792b/error-0001.jpg
