[GRASS-dev] Re: [GRASS GIS] #634: v.out.ogr error on Vista
trac at osgeo.org
Sat Aug 1 04:13:40 EDT 2009
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Resolution: | Keywords: wingrass, v.out.ogr
Platform: MSWindows Vista | Cpu: x86-32
Comment (by mmetz):
The attached patch is for debugging only. It contains two minor potential
fixes plus some more debugging info. I would like to find out where
exactly v.out.ogr stops. You can add G_debug() statements yourself to pin
down to exact point where v.out.ogr stops working, at least for me it
would then be easier to tackle the problem. Maybe gdb could also help, but
so far I did not find problems with gdb. Any tips on how to use gdb?
BTW, are other vector modules working for you, and is it Vista 32bit or
Vista 64bit?
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/634#comment:6>
