[GRASS-dev] Re: [GRASS GIS] #634: v.out.ogr error on Vista
trac at osgeo.org
Sat Aug 1 16:05:06 EDT 2009
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Resolution: | Keywords: wingrass, v.out.ogr
Platform: MSWindows Vista | Cpu: x86-32
Comment (by cnielsen):
Replying to [comment:6 mmetz]:
> The attached patch is for debugging only. It contains two minor
potential fixes plus some more debugging info.
The minor potential fixes seem to have worked. It works perfectly now.
Should I still post the debugging?
> BTW, are other vector modules working for you, and is it Vista 32bit or
Vista 64bit?
Other modules were working, and it is vista 32bit.
-Colin
Ticket URL: <https://trac.osgeo.org/grass/ticket/634#comment:7>
