[GRASS-dev] erorrs compiling i.pr modules
Markus Neteler neteler at osgeo.org
Sun Aug 2 05:06:55 EDT 2009
On Fri, Jul 31, 2009 at 6:40 PM, Dylan Beaudette<debeaudette at ucdavis.edu> wrote:
> On Thursday 30 July 2009, Markus Neteler wrote:
>> On Tue, Jul 28, 2009 at 9:46 PM, Dylan Beaudette<debeaudette at ucdavis.edu>
> wrote:
>> > On Tuesday 28 July 2009, Moskovitz, Bob wrote:
>> >> I ran into this problem before.  I believe the api has changes for a 2
>> >> argument Vect_build to a one.  See what happens when you remove the
>> >> second one.
>> > That did the trick. Patch is attached.
>> Thanks, fixed plus another compilation issue.
>> > It seems like there is no 'install'
>> > target for these files:
>> > $> sudo make MODULE_TOPDIR=/home/dylan/src/grass_6/ install
>> > make: *** No rule to make target `install'.  Stop.
>> Yes, because it is a set of subdirs and my skills aren't sufficient to
>> modify the Makefile rules to permit for recursive installation...
>> You need to walk through the subdirs and run it from there.
>> Since "make clean" runs recursively, it might be "easy" to apply
>> this also to "make install" but I would leave this to someone else.
>> Markus
> Thanks Markus. Unfortunately I don't know how to to this either...
I guess I figured it out: done in r38565 in GRASS 6.5.
To test:
- update i.pr for a small update
- update GRASS 6.5 include/Make
- compile/install GRASS
- try again with i.pr
- report here
Markus
