[GRASS-dev] Errors compiling grass6.4.0RC5 on a 64 bit Ubuntu 9.04 PC
Ferruccio Sarra ferruccio.sarra at tiscali.it
Sun Aug 2 06:37:32 EDT 2009
Ok Glynn.
After starting grass with no flags, this is the message in the terminal:
GRASS 6.4.0RC5 (UTM33WGS84EPGS):~/grass-6.4.0RC5 >
WARNING: Vector digitizer is not available (No module named grass6_wxvdigit)
If I try "3d view" ["Digitize"] in the Display window pulldown menu, the
result is:
Unable to switch to 3D display [vector digitizer] mode.
The Nviz python extension was not found or loaded properly.
Switching back to 2D display mode.
Details: No module named grass6_wxnviz [grass6_wxvdigit]
"nviz" command from terminal  works and opens a  wx look window  asking
for input data
"nviz -q" opens a tcltk nviz main widndow
I can find required modules in the downloaded folder where I compiled grass:
~$ locate grass6_wxvdigit
/home/ferruccio/grass-6.4.0RC5/gui/wxpython/vdigit/grass6_wxvdigit.i
/home/ferruccio/grass-6.4.0RC5/gui/wxpython/vdigit/grass6_wxvdigit.py
/home/ferruccio/grass-6.4.0RC5/gui/wxpython/vdigit/grass6_wxvdigit_wrap.cpp
/home/ferruccio/grass-6.4.0RC5/gui/wxpython/nviz/grass6_wxnviz.i
/home/ferruccio/grass-6.4.0RC5/gui/wxpython/nviz/grass6_wxnviz.py
/home/ferruccio/grass-6.4.0RC5/gui/wxpython/nviz/grass6_wxnviz_wrap.cpp
Another issue (don't know if related to the first one) is ... flying
mode doesn't seem to work properly and the camera moves forword/back in
a loopback.
This happens while working with
grass-6.2.3 from Ubuntu rep
grass-6.4.svn both wx/tcltk
grass-6.4-RC5 both wx/tcltk
grass-6.5.svn both wx/tcltk
installed on an Ubintu 9.04 64bit machine
*doesn't* happen with
grass 6.3.0 from Ununtu rep
installed on an Ubuntu 8.10 32bit machine
Thank you.
Ferruccio
Glynn Clements ha scritto:
>>> 1. What does running:
>>> 	/usr/bin/python2.5-config --cflags
>>> print?
>> ~$ /usr/bin/python2.5-config --cflags
>> -I/usr/include/python2.5 -I/usr/include/python2.5 -fno-strict-aliasing
>> -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes
>>> 2. What is the value of PYTHONINC in include/Make/Platform.make?
>> PYTHONINC           = -I/usr/include/python2.5 -I/usr/include/python2.5
> That looks reasonable. Can you post the errors, *including* the
> command which generates the error?
