[GRASS-dev] Re: [GRASS GIS] #695: Can't create a location using
Select Coordinate System option with WXGUI Location Wizard
trac at osgeo.org
Mon Aug 3 11:30:08 EDT 2009
#695: Can't create a location using Select Coordinate System option with WXGUI
Location Wizard
Reporter: voncasec | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: Location Wizard
Platform: Linux | Cpu: Unspecified
Comment (by martinl):
Replying to [comment:1 neteler]:
> Which parameters did you expect? We may be able to add them.
From ML:
I shouldn't have listed this as a major defect, because there are already
alternative options for selecting a coordinate system (e.g. using EPSG
code or proj4 definition). Its more of an inconvenience.
If I go through the location wizard and choose the "select EPSG code of a
coordinate system" option, I can navigate through the list, chose a UTM
projection using the NAD83 datum (e.g. Zone 10 N). After hitting the next
button I am given the option to choose my datum transformation option. The
first option says it is the default used in the whole nad83 region
(towgs84 = 0,0,0). However this default datum transformation option is not
available when I go through the "Select Coordinate System" option using
location wizard.
I guess I was expecting a "default" datum transformation parameter when
creating a location using the choose coordinate system option, similar to
how it exists with the select EPSG code option.
I have only noticd this with NAD83 projections so far.
Casey
Ticket URL: <http://trac.osgeo.org/grass/ticket/695#comment:2>
