[GRASS-dev] GRASS error after update to Ubuntu 9.10
roberto marzocchi roberto.marzocchi at gmail.com
Mon Aug 3 13:19:17 EDT 2009
Today I've updated Ubuntu 9.10 from Ubuntu 9.04
A Grass 6.4-0RC5 binary version is correctly installed (default) and it's OK
The GRASS installed from  source code give me this error:
*GRASS 6.4.0RC5 (WGS84):~ > *** glibc detected *** g.proj: double free or
corruption (fasttop): 0x08b4eee0 ***
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6[0x217e44]
/lib/tls/i686/cmov/libc.so.6(cfree+0x96)[0x219de6]
/usr/lib/libstdc++.so.6(_ZdlPv+0x21)[0x8af8ad1]
/usr/lib/libstdc++.so.6(_ZNSs4_Rep10_M_destroyERKSaIcE+0x1d)[0x8ad66fd]
/usr/lib/libstdc++.so.6(_ZNSsD1Ev+0x4c)[0x8ad810c]
/lib/tls/i686/cmov/libc.so.6(__cxa_finalize+0xb9)[0x1d9a09]
/usr/lib/libgeos-3.1.0.so[0x3748a54]
/usr/lib/libgeos-3.1.0.so[0x37f2370]
/lib/ld-linux.so.2[0xf54923]
/lib/tls/i686/cmov/libc.so.6(exit+0x89)[0x1d9679]
g.proj(main+0x410)[0x804a960]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0x1bf7c5]
g.proj[0x8049ad1]
======= Memory map: ========
00110000-00166000 r-xp 00000000 08:03 3786186
/usr/local/grass-6.4.0RC5/lib/libgrass_gis.6.4.0RC5.so
00166000-00167000 r--p 00055000 08:03 3786186
00167000-00168000 rw-p 00056000 08:03 3786186
00168000-0016d000 rw-p 00000000 00:00 0
0016d000-00181000 r-xp 00000000 08:03 1007806    /lib/libz.so.1.2.3.3
00181000-00182000 r--p 00013000 08:03 1007806    /lib/libz.so.1.2.3.3
00182000-00183000 rw-p 00014000 08:03 1007806    /lib/libz.so.1.2.3.3
00183000-001a7000 r-xp 00000000 08:03 1007724    /lib/tls/i686/cmov/
libm-2.9.so
001a7000-001a8000 r--p 00023000 08:03 1007724    /lib/tls/i686/cmov/
libm-2.9.so
001a8000-001a9000 rw-p 00024000 08:03 1007724    /lib/tls/i686/cmov/
libm-2.9.so
001a9000-00303000 r-xp 00000000 08:03 1007718    /lib/tls/i686/cmov/
libc-2.9.so
00303000-00304000 ---p 0015a000 08:03 1007718    /lib/tls/i686/cmov/
libc-2.9.so
00304000-00306000 r--p 0015a000 08:03 1007718    /lib/tls/i686/cmov/
libc-2.9.so
00306000-00307000 rw-p 0015c000 08:03 1007718    /lib/tls/i686/cmov/
libc-2.9.so
00307000-0030a000 rw-p 00000000 00:00 0
0030a000-00311000 r-xp 00000000 08:03 3524261    /usr/lib/libgif.so.4.1.6
00311000-00312000 r--p 00006000 08:03 3524261    /usr/lib/libgif.so.4.1.6
00312000-00313000 rw-p 00007000 08:03 3524261    /usr/lib/libgif.so.4.1.6
00313000-0031a000 r-xp 00000000 08:03 1007851    /lib/tls/i686/cmov/
librt-2.9.so
0031a000-0031b000 r--p 00006000 08:03 1007851    /lib/tls/i686/cmov/
librt-2.9.so
0031b000-0031c000 rw-p 00007000 08:03 1007851    /lib/tls/i686/cmov/
librt-2.9.so
0031c000-0031f000 r-xp 00000000 08:03 1007720    /lib/libgpg-error.so.0.4.0
0031f000-00320000 r--p 00002000 08:03 1007720    /lib/libgpg-error.so.0.4.0
00320000-00321000 rw-p 00003000 08:03 1007720    /lib/libgpg-error.so.0.4.0
00322000-00324000 r-xp 00000000 08:03 1007723    /lib/tls/i686/cmov/
libdl-2.9.so
00324000-00325000 r--p 00001000 08:03 1007723    /lib/tls/i686/cmov/
libdl-2.9.so
00325000-00326000 rw-p 00002000 08:03 1007723    /lib/tls/i686/cmov/
libdl-2.9.so
00326000-00388000 r-xp 00000000 08:03 3525238    /usr/lib/libodbc.so.1.0.0
00388000-00389000 r--p 00061000 08:03 3525238    /usr/lib/libodbc.so.1.0.0
00389000-0038d000 rw-p 00062000 08:03 3525238    /usr/lib/libodbc.so.1.0.0
0038d000-00395000 r-xp 00000000 08:03 3525699    /usr/lib/libltdl.so.7.2.0
00395000-00396000 r--p 00007000 08:03 3525699    /usr/lib/libltdl.so.7.2.0
00396000-00397000 rw-p 00008000 08:03 3525699    /usr/lib/libltdl.so.7.2.0
00398000-003a3000 r-xp 00000000 08:03 3524215
/usr/lib/libodbcinst.so.1.0.0
003a3000-003a4000 r--p 0000a000 08:03 3524215
003a4000-003a5000 rw-p 0000b000 08:03 3524215
003ab000-003f4000 r-xp 00000000 08:03 3525667    /usr/lib/libjasper.so.1.0.0
003f4000-003f5000 r--p 00048000 08:03 3525667    /usr/lib/libjasper.so.1.0.0
003f5000-003f8000 rw-p 00049000 08:03 3525667    /usr/lib/libjasper.so.1.0.0
003f8000-003fe000 rw-p 00000000 00:00 0
003fe000-00420000 r-xp 00000000 08:03 3624020    /usr/lib/libmfhdf.so.4.1r4
00420000-00421000 r--p 00021000 08:03 3624020    /usr/lib/libmfhdf.so.4.1r4
00421000-00422000 rw-p 00022000 08:03 3624020    /usr/lib/libmfhdf.so.4.1r4
00422000-00423000 rw-p 00000000 00:00 0
00423000-00479000 r-xp 00000000 08:03 3522952    /usr/lib/libtiff.so.4.2.1
00479000-0047b000 r--p 00055000 08:03 3522952    /usr/lib/libtiff.so.4.2.1
0047b000-0047c000 rw-p 00057000 08:03 3522952    /usr/lib/libtiff.so.4.2.1
0047c000-00483000 r-xp 00000000 08:03 3523364
/usr/lib/libkrb5support.so.0.1
00483000-00484000 r--p 00006000 08:03 3523364
00484000-00485000 rw-p 00007000 08:03 3523364
00488000-0048e000 r-xp 00000000 08:03 3522794    /usr/lib/libltdl.so.3.1.6
0048e000-0048f000 rw-p 00005000 08:03 3522794    /usr/lib/libltdl.so.3.1.6
0048f000-004b1000 r-xp 00000000 08:03 3525621    /usr/lib/libjpeg.so.62.0.0
004b1000-004b2000 r--p 00021000 08:03 3525621    /usr/lib/libjpeg.so.62.0.0
004b2000-004b3000 rw-p 00022000 08:03 3525621    /usr/lib/libjpeg.so.62.0.0
004b3000-004c3000 r-xp 00000000 08:03 3522735    /usr/lib/libtasn1.so.3.1.5
004c3000-004c4000 r--p 0000f000 08:03 3522735    /usr/lib/libtasn1.so.3.1.5
004c4000-004c5000 rw-p 00010000 08:03 3522735    /usr/lib/libtasn1.so.3.1.5
004cd000-004e2000 r-xp 00000000 08:03 3527404    /usr/lib/libgeos_c.so.1.5.0
004e2000-004e3000 r--p 00014000 08:03 3527404    /usr/lib/libgeos_c.so.1.5.0
004e3000-004e4000 rw-p 00015000 08:03 3527404    /usr/lib/libgeos_c.so.1.5.0
004e4000-0050a000 r-xp 00000000 08:03 3524090    /usr/lib/libpng12.so.0.37.0
0050a000-0050b000 r--p 00025000 08:03 3524090    /usr/lib/libpng12.so.0.37.0
0050b000-0050c000 rw-p 00026000 08:03 3524090    /usr/lib/libpng12.so.0.37.0
0050c000-00530000 r-xp 00000000 08:03 3526317    /usr/lib/libpq.so.5.2
00530000-00531000 r--p 00023000 08:03 3526317    /usr/lib/libpq.so.5.2
00531000-00532000 rw-p 00024000 08:03 3526317    /usr/lib/libpq.so.5.2
00540000-00541000 r-xp 00000000 00:00 0          [vdso]
00541000-005bd000 r-xp 00000000 08:03 3623995    /usr/lib/libdf.so.4.1r4
005bd000-005be000 r--p 0007c000 08:03 3623995    /usr/lib/libdf.so.4.1r4
005be000-005c0000 rw-p 0007d000 08:03 3623995    /usr/lib/libdf.so.4.1r4
005c0000-005e8000 rw-p 00000000 00:00 0
005e8000-0061a000 r-xp 00000000 08:03 3527410    /usr/lib/libnetcdf.so.4.0.0
0061a000-0061b000 r--p 00031000 08:03 3527410    /usr/lib/libnetcdf.so.4.0.0
0061b000-0061c000 rw-p 00032000 08:03 3527410    /usr/lib/libnetcdf.so.4.0.0
0061c000-0061d000 rw-p 00000000 00:00 0
0061d000-0064d000 r-xp 00000000 08:03 3525802    /usr/lib/libidn.so.11.5.44
0064d000-0064e000 ---p 00030000 08:03 3525802    /usr/lib/libidn.so.11.5.44
0064e000-0064f000 r--p 00030000 08:03 3525802    /usr/lib/libidn.so.11.5.44
0064f000-00650000 rw-p 00031000 08:03 3525802    /usr/lib/libidn.so.11.5.44
00650000-00658000 r-xp 00000000 08:03 3786336
/usr/local/grass-6.4.0RC5/lib/libgrass_datetime.6.4.0RC5.soError in startup
script: can't read "proj_is_ll": no such variable
    while executing
"if { $proj_is_ll } {
        # Explore mode is off by default (can't peer past 90deg)
        set exploremode($mon) 0
    } else {
        # Explore mode is on by..."
    (procedure "MapCanvas::create" line 38)
    invoked from within
"MapCanvas::create"
    (procedure "Gm::startmon" line 11)
    invoked from within
"Gm::startmon"
    (procedure "Gm::create" line 79)
    invoked from within
"Gm::create"
    (procedure "main" line 30)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-6.4.0RC5/etc/gm/gm.tcl" line 566)*
The same error come from GRASS 6.4 and GRASS 6.3!
Anyone have an idea?
Thanks
R
Un allegato HTML ? stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090803/00b88c33/attachment.html
