[GRASS-dev] [GRASS GIS] #716: The v.krige.py GRASS-Addons crash
related to wx.SpinCtrl
trac at osgeo.org
Mon Aug 3 15:53:53 EDT 2009
#716: The v.krige.py GRASS-Addons crash related to wx.SpinCtrl
Reporter: cgsbob | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: v.krige.py Grass-Addons | Platform: Unspecified
Cpu: Unspecified |
Running the command
v.krige.py input=elev_lid792_randpts at PERMANENT column=value
output=elev_lid792_randpts_kriging package=gstat
produces this error on a X86_64 Hardy Heron system:
GRASS 6.5.svn (nc_spm_08):~ > v.krige.py
Loading required package: gstat
Loading required package: sp
Loading required package: spgrass6
Loading required package: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.7.0dev, released 2008/11/26
Path to GDAL shared files: /usr/local/share/gdal
Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
Path to PROJ.4 shared files: (autodetected)
Loading required package: XML
GRASS GIS interface loaded with GRASS version: 6.5.svn
and location: nc_spm_08
File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 511, in
<module>
main()
File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 466, in main
k = KrigingModule(parent=None)
File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 375, in
__init__
self.Panel = KrigingPanel(self)
File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 267, in
__init__
self.CreatePage(package = Rpackage)
File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 324, in
CreatePage
setattr(self, "RBook"+package+"Panel", (classobj(self, id=wx.ID_ANY)))
File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 424, in
__init__
RBookPanel.__init__(self, parent, *args, **kwargs)
File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 400, in
__init__
setattr(self, n+"Ctrl", (wx.SpinCtrl(self, id = wx.ID_ANY,
max=sys.maxint)))
File "/usr/lib/python2.5/site-packages/wx-2.8-gtk2-
unicode/wx/_controls.py", line 2239, in __init__
_controls_.SpinCtrl_swiginit(self,_controls_.new_SpinCtrl(*args,
**kwargs))
OverflowError: in method 'new_SpinCtrl', expected argument 8 of type 'int'
It appears to be related to [https://bugs.cihar.com/view.php?id=24]
Ticket URL: <http://trac.osgeo.org/grass/ticket/716>
